Windows Update Problem
Windows updated itself while shutting down my computer yesterday.
Today when I tried to open Autocad it gives "Problem loading AcBrandRes.dll" error and does not open. When I try to uninstall it, it doesn't process and gives error again. I cannot do anything.
I don't have any kind of problem with Revit.
Alfred.NESWADBA
Which update(s) did it install?
Do you mean you uninstalled AutoCAD or the Windows update?
When you uninstalled the Windows update, maybe a repair-installation of AutoCAD can help.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you.
Windows automatically updated itself while I was shutting it down so I do not know the specific update.
After updating the windows, Autocad never opened again and gave that AcBrandRes.dll error. I searched some on the internet and I found something about uninstalling autocad. Then I tried uninstalling it and it gave another error refusing to uninstall. Windows is OK but not the Autocad:(
Alfred.NESWADBA
You can open the control panel, go to programs and features and there is a category for updates ... sort it by date.
To run a program on an operating system means ... both have to work together. If the program does not work it does not mean the program is defect.
As the Windows update was the only one that changed, then I would not start to repair AutoCAD.
(if the car's engine was changed and no does not start, I would not start looking to the tires ;))) )
- alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
Which Windows OS are you using on your computer? Is it possible to rollback the Windows update to see if AutoCAD still runs or can be uninstalled per this article?
The error you see does recommend uninstalling AutoCAD, C++ and the .NET Framework and then reinstalling the program. Let's see if the update rollback eliminates the other steps.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
To update your windows just follow the steps given below:
Go to Windows update Troubleshooter
Press “Windows + X” and run Control panel as Admin.
Search for “troubleshooter”, and then click Troubleshooting.
Under System and Security, click Fix problems with Windows Updates.
Also you can try this too:
Run command prompt as administrator.
Copy the following command
net stop
cd %systemroot%
ren SoftwareDistribution SoftwareDistribution.old
net start
Press enter.
Hope it will help.
Regards
Dany Gibson
Techrubik.com
