Greetings,
For many years, drafters at our firm have used SHX fonts to make white outlines with text. The text is duplicated, the back text having a wider pen width or line-weight and set to white. This method provides high quality drawing presentation, making all text legible on hatches or images.
We now want to change from SHX to TTF, opting to use the standard ARIAL Regular provided with Windows. But - how do you produce an outline with TTF? I found that the standard Windows SWIS 721 works well - 2 fonts provided, make sure the outline text is in front of the solid text. I guess I need an outline font for Arial - or is there another way? Where do I get / purchase that ARIAL outline TTF windows font ? Or ... is there maybe a way to make the font?
Thanks for your patience.
Kevin.
Image below ... SWIS below ARIAL, SWIS having 2 text objects..
