Windows 10 Compatibility
No aplicable
Is AutoCad 2015 compatable with Windows 10?
0 Me gusta
Responder
Soluciones aceptadas (2)
1.177 Vistas
5 Respuestas
Respuestas (5)
No aplicable
See the link re Windows 10 support over to the right =====>
0 Me gusta
No aplicable
I looked at the Link on the right, but there is not a definite answer. It still refers to Windows 10 being Beta tested. I have students who would like to know if the Autodesk products other than your 2015 version are compatible with Windows 10? I have looked at the links to the right but see nothing definite.
I cannot find anything either way.
0 Me gusta
No aplicable
Unfortunately, the info in that link is what ADSK has to say about it.  When they don't give absolute definite answers, I've found that it's their way of saying that you're free to install and use it on this OS, but you may be on your own if you have any major issues.  This forum has a lot of posts from folks saying that they are successfully using products on Win 10.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
If you read closely, AutoCAD 2015 English has a KB link to Microsoft that is needed:
"The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
The 2013–2014 versions of AutoCAD products will not be supported on Windows 10."
0 Me gusta
Emmsleys
Solución aceptada
To provide an update on this topic and thread. The following AutoCAD versions have been tested with Windows 10.
• AutoCAD 2016 is supported with the application of AutoCAD 2016 SP1.
• AutoCAD LT 2016 is supported with the application of AutoCAD LT 2016 SP1.
• The 2016 version of most AutoCAD-based verticals should be installable and perform as expected on Windows 10
Autodesk product versions of 2012 and earlier are no longer supported and are not included in considerations of Windows 10 compatibility.
The 2013–2014 versions of AutoCAD products will not be supported on Windows 10. For all links and further information on this topic please read over the AKN Article
Sarah Emmsley
Technical Support Specialist
0 Me gusta
