Will viewbase command work in standalone autocad without Inventor?
No aplicable
Hi everyone,
just a quick question about a point that was raised at work. One of the guys at work seems to think that viewbase command wont work without Inventor and I thought I'll double check and see if anyone can confirm or advise otherwise.
Cheers
Elroy
0 Me gusta
Responder
Soluciones aceptadas (1)
622 Vistas
5 Respuestas
Respuestas (5)
BeKirra
What AutoCAD version are you with?
IMO it depends on the AutoCAD version you have. AFAIK "viewbase" is an AutoCAD native command and it works with my v2016.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
imadHabash
Viewbase  command and since ( AutoCAD 2012 ) can creates a base view from model space or Autodesk Inventor models. there is no need ( as a must ) for an Inventor program but it has the ability to work with Inventor Models . also you have to know that this command is available only on 64-bit systems.
Imad Habash
No aplicable
We use APDSU '15 release. We want to mix up our current available licenses with a few AEC options. In the AEC suite we wont have Inventor, but we will have AutoCAD included in the suite. From what I can tell on the forums it's been available since 2012. Its a command borrowed from Inventor but I wouldn't have thought it would be Inventor dependant. I've tried it a few years ago, but found it limited compared to Inventor.
0 Me gusta
No aplicable
Thanks for the response. I didn't think so, but thought I'll double check before I say anything. We'll try it out on a standalone AutoCAD install. Thanks for the pointing out that the command is only available on 64-bit machine.
BeKirra
Solución aceptada
Yes, it is good to know this command is only available on x64 system. Cheers.
(I also remember it is not available in v2011.)
X² + Y² = C²
0 Me gusta
