Anuncios
Wildcard Character * Not Allowing Renaming of Multiple Layers
No aplicable
In the RENAME dialog, I am using the *wildcard character to rename multiple layers.
See Attached.
But No Layers are renamed.
What's the problem?
0 Me gusta
Responder
Soluciones aceptadas (1)
6.177 Vistas
20 Respuestas
Respuestas (20)
dbroad
I don't believe the rename command supports bulk renaming with wildcards.  You would need to write a program for that I think.
Architect, Registered NC, VA, SC, & GA.
0 Me gusta
kadmonkee
try changing the syntax
*Anno* doesn't match the actual name
you may need to include the tilde symbol
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
0 Me gusta
vladimir_michl
You can use RRENAME for complex renaming of AutoCAD layers and other named objects. It supports also regular expresssions.
See http://www.cadforum.cz/cadforum_en/rename-on-steroids-complex-renaming-of-autocad-objects-tip9265
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
0 Me gusta
No aplicable
Works fine here, I believe your issue result from using a wildcard character in the layer name itself.  The tilde (~) is a wildcard character and using it in layer names is probably affecting the rename capabilities.
dbroad
Looks like it will work for changing prefixes, but I can't make it change an internal substring.  Can you?
1-Layer1
2-Layer2
3-Layer3
4-Layer4
etc.
rename old name:*Layer*,  New name: *L*
won't work.
0 Me gusta
vladimir_michl
With RRENAME you can rename (just by entering "Layer" --> "L"):
1-Layer1 --> 1-L1
2-Layer2 --> 2-L2
3-Layer3 --> 3-L3
But you can even rename e.g.:
1-LayerA --> A-L1
2-LayerB --> B-L2
3-LayerC --> C-L3
by entering "(.+)-Layer(.+)" --> "$2-L$1"
0 Me gusta
serkancavuslar
Solución aceptada
Hi @Anonymous
Command "lrn"
LayerName Rename
Replace
Turkey / Istanbul
Serkan ƇAVUŞLAR
CplCAD / Türkiye
kadmonkee
here is a list of Acceptable wildcards for Autocad
Character
Definition
# (Pound)
Matches any numeric digit
@ (At)
Matches any alphabetic character
. (Period)
Matches any nonalphanumeric character
* (Asterisk)
Matches any string and can be used anywhere in the search string
? (Question mark)
Matches any single character; for example, ?BC matches ABC, 3BC, and so
on
~ (Tilde)
Matches anything but the pattern; for example; ~*AB*matches all strings
that don't contain AB
Matches any one of the characters enclosed; for example, [AB]C matches
AC and BC
Matches any character not enclosed; for example, [~AB]C matches XC but
not AC
Specifies a range for a single character; for example, [A-G]C matches
AC, BC, and so on to GC, but not HC
` (Reverse quote)
Reads the next character literally; for example, `~AB matches ~AB
thank you
No aplicable
In addition to @kadmonkee 's list it is important to remember NOT to use any of those characters in layer names (or any other name for that matter).
serkancavuslar
Some solutions can be very simple and practical.
This method is very easy and very practical as you can see.
Serkan ƇAVUŞLAR
CplCAD / Türkiye
No aplicable
Thanks for the .lsp file for advanced renaming functionality, since the standard RENAME dialog apparently does not permit multiple * characters.
It successfully solved my particular layer renaming task. It even successfully dealt with the tilde character I had as part of my layer name, which I removed as part of the layer name, since it is a wildcard character itself (kadmonkee's list & rculp's advice, thanks)
0 Me gusta
No aplicable
RENAME works quite well using wildcards, your problem was the wildcard character you used in the layer name. Don't do that and RENAME works fine.
No aplicable
Do you have a similar lisp file for renaming blocks?
ntodd
Observer
Observer
Someone has used '_' underscore instead of '-' hyphen in multiple layers. I want to change those layers to use a hyphen. The wildcards didn't work. Any thoughts?
Thanks!
0 Me gusta
RobDraw
Which wildcard did you use and how did you apply it?
Rob
0 Me gusta
No aplicable
I'm not sure why people are ignoring this, but this RRename, rocks! Thank you.
RobDraw
What makes you think it is being ignored?
Rob
0 Me gusta
No aplicable
this seems not to work for AutoCAD Archtitecture 2019. It just says unnown command "LayerName"
Any solution for this?
0 Me gusta
