Anuncios
Wierd display problem
mcgann001
mcgann001
Using 2020, had a problem which caused me to initiate an old profile. Ever since then, doing a command like move or copy etc., the first mouse click doesn't take. The second one does. When doing a crossing or window I get the same problem.  First left click, nothing then the second left click works. Also I've noticed the aperture which is normally square is now an upright rectangle. Obviously a graphics or display problem. I also have 2017 which works perfectly fine. I migrated my settings from 2017, everything came over and the options are all identical to 2017, but problem persists.  Thanks for any suggestions.
0 Me gusta
Responder
Soluciones aceptadas (3)
427 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
Solución aceptada
Which 2020 version do you have installed as listed by ABOUT command?
Or do you just need to turn off hardware acceleration in GRAPHICSCONFIG command in 2020? Things change with newer versions all the time, not just commands.
0 Me gusta
mcgann001
Looks like Q.47.0.0 Thanks
0 Me gusta
mcgann001
Solución aceptada
Turning off Acceleration seemed to help. Didn't fix the rectangle shaped aperture, but not a big problem.
Getting a new workstation next week, so everything will be re-installed. Probably will work out.
Thank you for your help.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Rectangle pickbox has a lot to do with your monitor and screen resolution in Windows https://www.google.com/search?q=autocad+rectangle+pickbox
2020 updates up to
0 Me gusta
mcgann001
Thanks!
0 Me gusta
