Happy New Year !
Thanks for your replying ......I am afraid the answer was not the one that solved my problem.
You can try to save a name for your view which shown in the second picture, then close the View Manager window. Restore that view to see what will happen~~~~The UCS will change the location where when the view to be saved! Even you have UCS ortho to the view.
The file you were using had problem since it was from the one which had such problem when I created a lot of views.
If you copy to a fresh file (Total New file), there won't have any problem for creating views and reloading the views, even you don't have UCS ortho to the view.
In my working drawing, so many views had been created before the problem happened and I couldn't find a way to copy all model with all saved views to a fresh new drawing. How come I can create and save so many previous one by one again!
That's the reason why I guess the file couldn't be repaired after such problem have happened (A certain amount of views to be saved and UCS will not work well when these view to be reload).
Thanks again for your taking time to solve the problem.
Laurel
