Why is dot pattern showing up on plots?
David125
Message 1 of 9
David125
A dot grid pattern is showing up on my pdf files. I didn't (knowingly) change settings. Any idea how to get rid of them? Sample is shown below.
Replies (8)
Message 2 of 9
Kent1Cooper
Are the dots also visible on-screen in the drawing?
Kent Cooper, AIA
Message 3 of 9
paullimapa
Are you using one of AutoCAD's built-in pdf devices to generate the pdf?
Enter PLOT command, do a screenshot and share the settings shown in that window.
Also share your dwg that has this issue & lets see if community can replicate your printing to pdf issue
Paul Li
IT Specialist
@The Office
Message 4 of 9
pendean
Community Legend
Community Legend
@David125 You need to share both your PDF with the dots and the DWG it was created from please.
Message 5 of 9
David125
I'm using the default "DWG To PDF.pc3", and I've tried it using bluebeam with the same results. That tells me I hit a setting somewhere and I don't know what that might be. It occurs on all drawing, new and old. If you don't get those dots, that tells me I "hosed" something on my side.
Message 6 of 9
paullimapa
Can you also attach the pdf you generate from the sample dwg you attached that shows the dots?
Paul Li
IT Specialist
@The Office
Message 7 of 9
David125
I missed, that one. Here it is.
Message 8 of 9
David125
Time for me to make the walk of shame. I've eliminated AutoCAD as the culprate. I think it is a Bluebeam setting because it looks fine when opened with Acrobat reader.
Update: Confirmed, Bluebeam is the culprit, now I can shut it down on a drawing I call up but it reappears when opening another drawing. Time to give Bluebeam a call on that one.
Message 9 of 9
paullimapa
glad you got that solved...cheers!!!
Paul Li
IT Specialist
@The Office
