Hello @akmalrafiq
As suspected the objects have "Z" values due to which you are not able to perform the HATCH function. Please see the attached images.
However, I was able to hatch the rectangle which doesn't have any problem. If you are not able to see the hatch applied to the rectangle then, type in the command "3DCONFIG" and check if its turned "on".
Object containing Z values
Side view of the object showing that they are not on 2D plane
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
