Why does the drawing not open?
Message 1 of 8
When receiving a 3D survey from a company the drawing fails to open with no error code or any other information but the 2D survey opens straight away.
Why is this?
Replies (7)
Message 2 of 8
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums !
1) Please which version of ACAD: 2018, 2017, 2016, etc ?
And which ACAD exactly: ACAD, ACAD LT, ACAD MAP, ACAD CIVIL, ACAD Architecture, etc ?
2) On which Windows: 7, 8.0, 8.1, 10 ?
3) Have you tried to open your DWG/DXF in RECOVER Mode ?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 8
ACAD 2017, Full ACAD on Window 10 and have tried option 3. Just noticed we can open this on ACAD LT but not full CAD
Message 4 of 8
-FDC-
Acad LT also 2017 ?
Message 5 of 8
ACAD LT 2018
Message 6 of 8
Alfred.NESWADBA
Do you have a vertical product like AutoCAD Architecture or AutoCAD Civil 3D ... or at least an object-enabler installed with AutoCAD?
Or do you have any apps/tools installed which are sitting on top of your AutoCAD?
If you can upload the dwg-file we can test it on our systems, if we crash too.
Please start AutoCAD (full), run command _ABOUT and show is a screenshot from that dialog!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 8
-FDC-
Than it is clear !
It is saved as 2018.
You should open it in autocad 2018 or save it as 2013.
Autocad 2017 cannot open 2018 files.
Message 8 of 8
Alfred.NESWADBA
sorry, posts crossed ...
>> ACAD LT 2018
AutoCAD 2018 has a different file format, you need to save back to DWG2013 format in your AutoCAD LT so AutoCAD 2017 can open this drawing.
- alfred -
Alfred NESWADBA
