Why does QSELECT list XREF layers?
sparker9JZGB
sparker9JZGB
I have a drawing with several floorplan XREFs. When I use the QSELECT command to select objects by the layer property, the dialog box lists all the XREF layers (which outnumber my actual working layers five times over).
Additionally, this list isn't sorted by my layers, then the XREF layers; it's sorted alphabetically, meaning depending on how the Xrefs are named, my layers might be spread throughout this list. I can mitigate this by using a consistent prefix, but it's annoying at best.
So far as I know, there is no way to create, select, or modify objects on an XRef layer without opening the XRef (or editing in-place), so listing these layers in this context seems useless. Is there a reason?
cadffm
>"So far as I know, there is no way to create, select, or modify [NESTED] objects on an XRef layer without opening the XRef (or editing in-place),
Right
>"so listing these layers in this context seems useless."
Correct
>"Is there a reason?"
The only reason I can imagine is: Qselect don't need time to verify which layer is in used and what layers not.
But specially of Xref-Layers, it isn't a performance question, that's just because of the programmer and the examiniers had no idea about AutoCAD object selection rules.
Sebastian
pendean
Community Legend
Community Legend
@sparker9JZGB Are you not aware you can give your XREF a different name in the top file? So layer sorting is my name, adding a small x to the name pushes your XREF layers to the bottom of the list.
Do you use Layer FILTERS at all?
sparker9JZGB
Yes, I'm aware I can mitigate layer mixing by using prefixes, filters, and renaming XRefs.
My question is specifically why QSELECT behaves this way (and to maybe attract the attention of someone who can properly fix it).
cadffm
The ONE is Autodesk only 😞
Sebastian
pendean
Community Legend
Community Legend
@sparker9JZGB wrote:
...My question is specifically why QSELECT behaves this way...attention of someone who can properly fix it...
It is what it is. Know anyone at Autodesk programming AutoCAD to ask? Then you are stuck asking for a change to future versions (if they even want to do it) here https://www.autodesk.com/company/contact-us/product-feedback
