Why does my line start automatically on the last end point?
Message 1 of 8
So I am using Autocad 2013. There is a weird problem that I face. Initially when I use the autocad everything is normal. However 10-15 minutes after using autocad, when I use my line command - my line automatically starts from the last point I left it in autocad. And in the command window I get a message - "Specify next point or [undo]: " Now I have to press undo so that I can select the starting point of my line.
Any idea as to why such a thing happens?
Why do I not get the normal default option of "Specify first point:"?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
What exactly means "my line command" ... do you have a tool that does something special or what is it?
Next time this happens try to type into the command line:
_.LINE<ENTER>
(including underline and point)
Are you then asked for the first point?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
my line command simply means - I type in L space (shortcut for line) in the command prompt.
I tried using the _.line in my command prompt, but it still starts from where I left!
Message 4 of 8
Alfred.NESWADBA
does it make a difference if you use
_.LINE<ENTER>
_.LINE<SPACE>
Do you have any special devices like a mouse with > 2 buttons, cable-less keyboard, 3d-mouse or something like that?
What version of AutoCAD do you have and what is the service pack you have installed currently (command _ABOUT shows it in the dialog).
- alfred -
Alfred NESWADBA
Message 5 of 8
Hey!
Yes it does make a difference!
_.Line<ENTER> would result in asking "specify the first point" whereas
_.Line<Space> would result in asking "specify the second point <undo>" with the starting point of the line starting automatically from the last point where I left it in drawing some other line!
Can you please explain this sorcery?
I am not using any special devices, except for a simple Logitech wireless mouse (Logitech M165).
I have autocad 2013 installed in my laptop and it doesn't really show what service pack I have installed with that command.
Ashish Hirani
Message 6 of 8
Alfred.NESWADBA
Start command _ABOUT and show us a screenshot from that dialog.
If you have not done any customization's you  can try to reset the AutoCAD settings to default and see if that helps >>>click<<<.
If you have done any customization's then please let us know which ones.
- alfred -
Alfred NESWADBA
Message 7 of 8
Kent1Cooper
It sounds to me like a keyboard problem -- that your space bar is registering twice when you press it.  Starting a Line command and then hitting Enter/space starts the Line from the end of the latest Line or Arc or Polyline drawn [and at a tangent continuation direction if that was an Arc or Polyline arc segment].  You should get the same second-point prompt if you do Line <ENTER> <ENTER>, assuming an Enter key that is not similarly registering double.  A further test: try Line <Space> in a new drawing, in which you haven't drawn anything yet, and if you get a "No line or arc to continue" message, that can only be the result of a double Enter/space, not of any customized definition of the Line command or something.
A Space-bar malfunction would also explain why it sometimes happens and sometimes doesn't, since a mechanical issue can be sporadic.  Its being normal for a while before the problem develops could be a matter of the condition developing as things warm up.
Kent Cooper, AIA
Message 8 of 8
The problem has been solved. Thanks guys for all the prompt answers!
However, I just uninstalled and reinstalled AUTOCAD on my laptop and everything was back to normal!
