Anuncios
Why does my block turns into messy lines after converting into pdf?
No aplicable
I am really having a hard time fixing this issue. When I am in the model, the blocks are all okay but when I convert it into pdf, blocks became so messy. Please help.
See attached screenshot on the pdf
0 Me gusta
Responder
1.231 Vistas
8 Respuestas
Respuestas (8)
imadHabash
can we have a part of your CAD drawing file for testing please ( attache it here ) ?
Imad Habash
0 Me gusta
No aplicable
I have to delete some parts of the drawings, and I noticed that whenever I delete then plot the document, the zigzag look of the chair blocks diminishes also. It became smoother unlike the whole drawings.
So I attached the file, and if you convert this into pdf, the chairs looks so messy. It is not solid , it has open joints and very ugly looking
0 Me gusta
ennujozlagam
just tried to plot into pdf and it looks okay. try to change your ctb plot setting line thickness and see if helps. thanks
0 Me gusta
imadHabash
I have a good final result and without a problem !!! I think that you need to check and review again your Plot settings . select the right and proper paper and scale then untick plot object lineweights , any changes ?
Imad Habash
0 Me gusta
ennujozlagam
mabuhay.....:cara_guiñando_un_ojo:
0 Me gusta
No aplicable
Sorry but this dont work on my file.
0 Me gusta
ennujozlagam
try these attached file including plot style and see if helps. thanks
0 Me gusta
ChicagoLooper
Do you run Adobe Acrobat?  If you do, change your printer in the Plot Window like this:
Chicagolooper
0 Me gusta
