Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Why does AutoCAD keep changing length/values and how do you deal with?
7 REPLIES 7
Message 1 of 8
leander.gaeb
509 Views, 7 Replies
For example, I draw the property line and need to keep a 5m distance to the street and a 3m distance to all other lines, so I use the offset tool twice and draw the outline of the building using the edges and the intersections of the offset-lines. When I return at a later point the distance has shifted by a tiny fraction to something like 4.99974m instead of 5m.
Not a huge difference but it can add up if it keeps happening and I keep using the outline as a frame of reference.
So, is there any way to prevent it (aside from using parametric constraints on EVERYTHING) and if not, how do you deal with it?
7 REPLIES 7
Message 2 of 8
RobDraw
in reply to: leander.gaeb
This can happen if you are far from (0,0).
Rob
Message 3 of 8
imadHabash
In addition of what mentioned in the previous post .. you can from UNITS command change the Precision to 0,00 .
Imad Habash
Message 4 of 8
leander.gaeb
in reply to: RobDraw
So I can just not stray to far from base 0,0?
Message 5 of 8
Kent1Cooper
You can stray pretty far, within reasonable sizes of real things, before it starts to become a problem.  But we've seen people with similar problems post drawings with coordinates that were farther from the original than the diameter of the solar system -- I remember seeing values in the range of 10-to-the-14th-power....  How far away are you?
Kent Cooper, AIA
Message 6 of 8
leander.gaeb
in reply to: Kent1Cooper
Between 40 and 500?
Message 7 of 8
cadffm
Lower xyz than +/- 1.000.000 is perfect.
(Note, they are talking about 0,0 wcs - doesn't matter your current ucs)
My question is another one: Your sample with length 5.
Are you sure that the line was ever
5 long?
I guess the line wasn't 5 long and you didn't test it directly.
Another case: Between creation and your length check (4.99..).
Wasn't there a scaling since you created the line.?
Sebastian
Message 8 of 8
RobDraw
You seem to be under the impression that the program is not accurate. That's very far from the truth. Something is happening on your end to cause this. I thought it might be the distance from (0,0) but that doesn't appear to be the case.
Please provide a file and the steps you take to reproduce this problem.
Rob
AutoCAD Inside the Factory
