Why does Acad think I want a 45 degree rotated linear dimension whenever I use the DIM command?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So, I wouldn't say I'm an expert in Autocad, but I can eventually figure out most trouble-shooting problems.
But this one has totally stumped me.
All of a sudden, Autocad is forcing a very specific kind of dimension on ordinary lines all the time. I use the standard DIM command, but the dimension it generates is anything but. It seems to be a rotated linear dimension with an angle of 45 degrees. Only, I want to know how long my dang line is, not how far apart two parallel lines extending from both endpoints at 45 degrees are!
My main problem in figuring this out is that I have no idea how to go about doing it if I wanted to. I've looked through every single system variable starting with DIM and none of them are causing it.
I just want to know if anyone else has ever had this problem.
BTW, it was just in that one drawing, too. Other drawings are fine, even with every setting seemingly exactly the same. But I deleted everything I possibly could from that drawing except one solitary polyline, changed my dimstyle and text style to standard, but still it persists! Interestingly, it only happens when trying to dimension with the UCS rotated about the x axis 90 degrees. At the home UCS orientation it works like normal.
So, if anyone has seen this before, I'd really love to know about it.
