In the attached dwg you see four 3DFaces. Three of them can I extrude, the fourth (red) is always removed from the selection set of the extrude command.
Why I can not extrude (and also not revolve or sweep or other 3D operations) this object.
In >>this video<< you can see what I did. Be aware: if I move this 3DFace a little, then it can be extruded (and other operations too).
What is wrong with this object, what can I do to avoid this behavior?
Additional information: This 3dFace is one of thousands of 3DFaces, which I want to extrude. some of them (seemingly randomly, I can't find any "rules") show the same behavior. (Tested in ACAD 2020 and 2021).
Does anyone have an idea how to solve the problem?
Jürgen Palme
