why 1024 is maximum number in polygon ?
Hello Everyone
I heard that maximum number of sides with which a polygon can be made in AutoCAD is 1024. Why 1024 ?
Thank you
Alfred.NESWADBA
>> Why 1024 ?
Just guessing as I'm not the developer who decided that
  • Because a bigger value would need one bit more to be stored.
  • And from my point of view ... more than 1024 would make the object looking like a real circle.
When do you need a higher value?
As a workaround: use command _ARRAY.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
Why not?
RobDraw
It might have something to do with the fact that it is the square of 32 (bits).
Rob
parkr4st
go back further to binary days      2 to the 10th power     days of DOS limits or earlier most likely
