While i try and Sync one particular drawing, i get an error Sync Failed
No aplicable
Using AutoCAD2013.
I'm able to sync other drawings but facing issue with only one drawing.
What should i do?
Edited by request
Discussion_Admin
0 Me gusta
Responder
474 Vistas
7 Respuestas
Respuestas (7)
pendean
Community Legend
Community Legend
sync to/from where exactly?
0 Me gusta
No aplicable
from AutoCAD to IBM Tririga
0 Me gusta
pendean
Community Legend
Community Legend
You will need to reach out to IBM TRIRIGA's support for help with their product and sync feature https://www.ibm.com/support/home/
0 Me gusta
No aplicable
But other drawings are getting synced , except one
0 Me gusta
pendean
Community Legend
Community Legend
Can't help you, IBM TRIRIGA is not a common tool around here.
Files usually don't sync for these common reasons at other services, explore them while you reach out to their support https://www.qnap.com/en/how-to/faq/article/why-can-i-not-sync-some-files-to-cloud-services
0 Me gusta
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
While I agree with Dean' assessment that this is likely a sync problem on the storage side of the equation, I am happy to look at the file if you can share it. I will look for any corruption, large size, xref's and attachments, missing fonts, etc.
John Vellek
0 Me gusta
Mistress0fTheDorkness
If I was experiencing this issue, I would detach the file from the database, purge, -purge/regapps and run audit, before reattaching the file to the database and trying again.
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
0 Me gusta
