Anuncios
Which Windows registry keys for Autodesk product installation?
No aplicable
Dear Autocad Expertise,
Here I would like to check which Windows registry keys if the PC had ever installed any version of Autodesk products in order to prevent / counter-check any illegal Autodesk products installed in the PCs.
Raymond Cheung
Responder
Soluciones aceptadas (1)
37.578 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
You can use the FIND feature (under the EDIT menu) in the Windows Registry application, search for Autodesk and AutoCAD terms.
0 Me gusta
No aplicable
But it is too many key with the keywords " Autocad" or "Autodesk" .
In addition, is there any documents / websites to show the meaning of version code.
e.g. Autocad2015 - version code shown in registry is R20
       Autocad2014 - R19.1
       Autocad2013 - R19
       etc....
      How about other Autodesk product, such as Building Design Suite, Revit, ... ? what is the version code in registry?
Thanks in advance.
Raymond Cheung
0 Me gusta
Victoria.Studley
Solución aceptada
Hi @Anonymous,
Thank you for posting your question here. In addition to @pendean's advice to use the "Find..." feature to locate all Autodesk registry keys on a machine, you could also refer to the instructions for performing a clean uninstall of all Autodesk programs. In the section titled "Delete remaining Autodesk product entries from the Windows registry", you'll see the registry locations listed.
You can determine the version number of an AutoCAD-based program by navigating to the C:\ProgramData\Autodesk\AutoCAD 20XX folder:
I can't speak to any of the products outside the AutoCAD-based programs, but there is likely to be a similar location in the folder structure of each product.
R20.1 = AutoCAD 2016
R20.0 = AutoCAD 2015
R19.1 = AutoCAD 2014
R19.0 = AutoCAD 2013
R18.2 = AutoCAD 2012
R18.1 = AutoCAD 2011
R18.0 = AutoCAD 2010
R17.2 = AutoCAD 2009
This reference came in handy, and you might find some additional useful information there for what you're trying to accomplish.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
No aplicable
I've got the detail Autocad product version no. in the following link.
http://jtbworld.com/autocad-information#AutoCAD-registry-details
0 Me gusta
