Which laptop is better for running AutoCAD and Revit?
No aplicable
Hi there,
which laptop is better for revit and autocad?
surface laptop 2 (i7,8g ram)
dell inspiron 5000 5593 (i7 , 8g ram)
@Anonymous
Topic title has been changed for better findability by @Tiana_Y Original: Which one is better?
0 Me gusta
Responder
Soluciones aceptadas (2)
1.727 Vistas
5 Respuestas
Respuestas (5)
imadHabash
Solución aceptada
HI,
you can take a look here . >> Click <<
Imad Habash
0 Me gusta
Alfred.NESWADBA
@imadHabash
I would not recommend this list as it shows laptops which even don't have the minimum requirements according to the AutoCAD system requirements (e.g. 1.9GHz processor rate) or showing a graphic card GTX960M which is 2 generations older than current, or 13" display which I would never see as a display size you can efficiently work with Revit (or AutoCAD).
@Anonymous
Please show us links to the exact devices, because these devices can be shipped with different graphic cards.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
0 Me gusta
Alfred.NESWADBA
Solución aceptada
first one has only an Intel HD graphic card, which is not really built for CAD.
Also a screensize of 13" would be much too small for me.
The second one has at least a better graphic card, but I don't see the display size.
If 8GB memory is enough depends on your projects, for small projects it works.
- alfred -
Alfred NESWADBA
0 Me gusta
Grover_Puma
AUTOCAD requirements any version
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
REVIT requirements any version
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
0 Me gusta
