Where is SnapAng command in CUI?
Message 1 of 17
I cannot find "snapang" command in the command list CUI (Customize User Interface). Does it have a different name?
Wojtek
Replies (16)
Message 2 of 17
cadffm
Not predefined, create your own "command"
'_.snapang;45
Sebastian
Message 3 of 17
thank you for your answer.
The problem is that I want use "snapang" command with my side mouse button, but to do it I have to transfer this command from Command List to Customizations in All Files in CUI.
Any ideas how can I solve this problem?
Message 4 of 17
imadHabash
>> I cannot find "snapang" command in the command list CUI . Does it have a different name?
SNAPANG NOT a command , SNAPANG  is a System Variable .
Imad Habash
Message 5 of 17
Thank you for Your answers.
Is there a possibility to drag out "snapang" to the Toolbar then?
Message 6 of 17
imadHabash
No ... as much as i know .
Imad Habash
Message 7 of 17
So strange.... I cannot believe this… 😞
Message 8 of 17
cadffm
I am not sure what you need, but it is not a problem
1. to have "Snapang" in the command list in the lower left part of CUI command
   Create your own new command there.
2. also possible to set "Snapang" to a shortcut (your mouse should be able to use it)
If I pass the subject, please excuse me.
Please upload a picture of a valid "command" where you need snapang inside CUI dialog?
And if possible, also a picture of you Mouse Setting where you set up this command.
Sebastian
Message 9 of 17
You understand my problem very well.
The problem is that I have no idea what should I Write in to fill up all gaps to create a new command…
I read on internet how to create it but with no results 😕
Would you please give me an advice?
Message 10 of 17
cadffm
'_.snapang;45
Sample for value 45..
Sebastian
Message 11 of 17
OK. Nice. We are closer!
I wrote this line in the "Macro" section.
But it turns the angle 45 degrees. This what I want to do is to use snapang command, then mark 2 point on the line so I would get the same angle as the line... The thing is that I change different angles according to the lines in the drawing.
Message 12 of 17
cadffm
then remove ";45" from the end of the macro
Sebastian
Message 13 of 17
Thank you!!! Oh my god you made my life much easier!
Can we og one step forward? Do I need en external program to set this command on my mouse or is it possible to do this in Autocad?
Message 14 of 17
Kent1Cooper
@Anonymous wrote:
.... what I want to do is to use snapang command, then mark 2 point on the line so I would get the same angle as the line... The thing is that I change different angles according to the lines in the drawing.
AlignSnapAng.lsp, with its AS and ASB commands, available >here<, is designed to do just that, and you don't  need to mark 2 points -- just select the Line at one  place, or nearly any kind of thing [see the file and the description at that Message], and the SNAPANG System Variable will be set to align with it, and under the ASB command, the SNAPBASE System Variable will also be set relative to it.  See also further discussion on that thread.
Kent Cooper, AIA
Message 15 of 17
@Kent1CooperHey. This is great. I can do this twice faster with Your solution.
It Works very nice but please tell me how can I change back the angle to 0 degrees after changing the angle according to the line?
Message 16 of 17
Kent1Cooper
I have a little macro in a Tool Palette button that does this:
  'snapbase 0,0 'snapang 0
That could also be defined into a command name, if that would be easier for you:
(defun C:AZZ (); = Align back to Zero and Zero
  (setvar 'snapbase '(0 0 0))
  (setvar 'snapang 0.0)
Kent Cooper, AIA
Message 17 of 17
Big thanks!!! 🙂
