How do I find where the AutoCAD commands are stored?
ACADDOC.LSP where is this file located?
You can not see AutoCAD-Command definitions, except few Expresstools (not supported).
ACAD.lsp and ACADDOC.lsp is a user defined file, it isn't part of the program/install.
If you want to have one, you can create your own.
Why do you ask these questions?
Sebastian
I was hoping I could add new commands to it so that they could automatically load when AutoCAD is open.
Create a new Textfile, save the file as ACADDOC.LSP and save the file in one of your Supportpathes.
(You can create your own folder and add them to the Support pathes. Options/Files/Supportpathes)
But there is another option too, Start command APPLOAD and add your lsp files in the StartUp Suite!
Command APPLOAD [F1]
and this: http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-B38F610B-51FB-4938-BDEC-A0A737F5DB6C
Sebastian
I just installed Autocad Electrical and it has an ACCADOC.lsp file in C:\Program Files\Autodesk\AutoCAD 2019\Acadm. Should this file be altered or replaced?
I am not so familiar with ACADE, but well enough to help you.
On this PC, there is no AutoDESK MECHANICAL installation??
I am surprised about about this folder, if it comes with the ACADE install.
(but as i said, i am not familiar with ACADE and i am away from my PC)
If MECHanical is also installed:
Do not edit or replace this file, i am sure this folder is not part of your ACADE Supportpathes.
Short test, start ACADE and type in:
(findfile "acaddoc.lsp")<enter>
Is the feedback = nil or a path?
NIL = Thats good, it means that your profile don't load this acaddoc.lsp.
So if it is nil, create your own personal folder and create your own ACADDOC.lsp there* (local drive with a backup on your server or a USBstick).
Don't forget to add this path to your supportpathes.
Options/Files/Searchpath for Supportfiles..
And also you have to add this path to the TrustedFolders, also in Options/Files/..
(Findfile "acaddoc.lsp") should find your file then.
*Notepad/Editor, change the extension to .lsp
Thats all. ACADDOC.lsp
Sebastian
