AutoCAD Forum
When Opening a File Autocad requires a recovery and deletes all basic 3D solids
12 REPLIES 12
Message 1 of 13
CodyMilne
3648 Views, 12 Replies
CodyMilne
The drawing saves and closes without any errors or crashes. When you re-open it Autocad will have the pop up that the drawing must be recovered. After running recovery it finds numerous errors and fixes them and erases all 3D solids. This has happened to several different computers in my office, Across multiple files and different job folders. We all run Autocad 2018 and from other forums that I have viewed it appears to be an issue with this version. Has anyone had a fix for this or a way to not loose hours of work restoring .bak files or going to older versions to redo the work. Again this on erases basic 3D solids such as rectangles or joined polylines that were extruded.
Attached are the dwg's of the original file before saving for the day and after when you open it and it wants to run recover. You will notice even inside blocks that have 2D lines and one extruded object that the 3d solids have been erased.
We do use a 3rd party software to draw ductwork but none of those objects are affected.
Running - Autocad 2018
Windows 10 Pro
32 GB Ram
Intel(R) Core(TM) i9-7900X CPU @ 3.30GHz
NVIDIA Quadro P4000
Windows 10 Pro
32 GB Ram
NVIDIA Quadro P4000
12 REPLIES 12
Message 2 of 13
pendean
in reply to: CodyMilne
pendean
Community Legend
Community Legend
Other than trying different methods to recover your file https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA... or finding not so old BAK or SV$ files to rename and recover more contenthttps://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Understanding-AutoCAD-backup-and-autosave-files.html , I'm not sure what you can expect others over here to do for your files.
Looking at your files' content, it appears you all may benefit from using XREFs more and limit the amount of loss to portions of files instead of ALL of your content at once too
Message 3 of 13
CodyMilne
in reply to: pendean
CodyMilne
I don't expect anyone to do anything for the files. I was just wondering if this is only limited to the 2018 version. I have reviewed others post's on the topic it seems to be limited to 2018 versions whether its regular, Mechanical, or Architectural. Would upgrading everyone to 2019 or even 2020 alleviate the issue? Using more XREF's will not solve anything. The backgrounds are already separated via XREF in the file and the only objects displayed are text, 3D ductwork, and 3D Solids in model space. The only content that is erased is the 100 or so 3D solids that make up some equipment. Going back to a .bak file or autosave constantly shouldn't be the answer, which is what we are doing right now.
Message 4 of 13
pendean
pendean
Community Legend
Community Legend
No, if this was a problem in a now 2-year old software like R2018 there would be thousands of similar posts, not a handful or a few that are not limited to just R2018.
Sadly no one can answer your question really, we only have your before-and-after files, we have no idea how you store files nor access to your server: i could be bad blocks (hence the purge), or there was an issue with your server and backups were unsuccessfully recovered, or could be something totally unrelated too.
>>>...Going back to a .bak file or autosave constantly shouldn't be the answer,...<<<
No it isn't, I was just offering you a way to recover what you lost. If you have to hunt for BAK and SV$ all the time to recover corrupt files I would start looking at how you all store and backup files, then double-check all of your reused/new content for corruption that is leading to files getting trashed.
HTH
HTH
Message 5 of 13
cadffm
cadffm
@pendean
There are a lot of thread, also a huge count of support-cases..
@CodyMilne
" Would upgrading everyone to 2019 or even 2020 alleviate the issue"
No.
The only way i know (if THIS is the case here / i can not check the files now)
is to disable the undocumented automatic 3dsolid audit.
Not really good idea, but for some cases the only way (for me).
I will check your files tomorrow.
Sebastian
@pendean
@CodyMilne
No.
Sebastian
Message 6 of 13
cadffm
cadffm
@CodyMilne
Do you mean ALL 3DSolids in one?
And "needs to recover" message?
Sorry, i am sure this isn't the problem i thought.
My fail in hurry.
I have to check the the files first (tomorrow)
It is late, bye
Sebastian
@CodyMilne
My fail in hurry.
It is late, bye
Sebastian
Message 7 of 13
CodyMilne
in reply to: cadffm
CodyMilne
Thank you for helping me investigate this.
The window says "the drawing file requires recovery"
Yes it only erases all 3D solids. It doesn't seem to matter if it is a basic 3D solid that was a square extruded or even if they are in a block with other objects (Lines, text, whatever) the 3D solid will be erases and the block will remain.
In the files where happens you can open up the previous save and run Recover/Audit/Purge. No errors are found and nothing is erased. So I am really not sure what is causing this to happen in the program.
Message 8 of 13
cadffm
cadffm
at time  i can not test it with a 2018 version, but 2019.
1. The recover log point to the spatial index
2. My 2019 also find an error about the spatial index in your "9673_21st Floor_04-30-19_CT.dwg"
    and it was able to fix the problem.
Please try it again to _RECOVER the "9673_21st Floor_04-30-19_CT.dwg" file and use this file with the fixed spatial index problem to continue your work.
Is your 2018 detecting the error and solve it?
I can not know if all the other cases with you also show spatial index problems,
you have to read this yourself in the log.
Check the textscreen [F2] or you can also activate the audit log by using AUDITCTL, acad will create *.adt logfiles
in the drawing folder then. Open the *.adt and search for SPATIAL (ctrl+f or look at the end)
If it is the case, try to work a time without the spatial index.
Sebastian
Sebastian
Message 9 of 13
darionl33
darionl33
Community Visitor
Community Visitor
This is not JUST ACAD 2018, as i am on 2019 and running into the same issue
Message 10 of 13
JoeVernice
JoeVernice
@CodyMilne
You are not alone, I too have had this exact issue. Recovery failed to bring back any of the deleted solids, always had to revert back to the previous day's file.
JMV
@CodyMilne
JMV
Message 11 of 13
cadffm
in reply to: darionl33
cadffm
As you can read above...yes.
No.
Because Adesk changed the internal 3dsolid audits in 2018,
and there are much problems with files(and 3Dsolids objects) from older versions,  so all other (newer) versions do the same.
If i am right - there are not more or less problems as in other versions if you start a new file based on a clean dwg2018 (in 2018/19/20..)
and creates new 3Dsolids with these versions.
and
Sebastian
No.
and
Sebastian
Message 12 of 13
geraldbossink
geraldbossink
Experiencing the same problem (loss of 3D solids when forced to recover) I tried the solution above, but in the *.adt is nothing like 'spatial' (see the *adt I had to convert to *.txt, since the *.adt can't be attached somehow). This is a really annoying problem, since it occurred to a drawing I completed weeks ago.
Also: recovering deletes the solids, but opening without recovering also deletes the solids. So either way the drawing is useless.
Message 13 of 13
phRJ5A8
phRJ5A8
I have the same problem with autocad 2024, multiple files on different computers, all ending up with erased 3d objects.
AutoCAD Inside the Factory
