When inserting block, it appears too far away from the crosshair
No aplicable
I have been using AutoCAD 2021 for a month so, forgive my lack of knowledge. I am second year Civil Engineering student.
Anyway, whenever I insert a block, it always appear too far away from the crosshair. I've tried everything I have read here in Forum as well as in Reddit however, all of the suggestions were not working.
Attached below is the proof of my problem:
The yellow circle is the block I did. Look at the distance between the block and the crosshair.The yellow circle is the block I did. Look at the distance between the block and the crosshair.
Badly needed your help. Big thanks!
0 Me gusta
Responder
3.309 Vistas
4 Respuestas
Respuestas (4)
vinodkl
You created object little far from the 0,0 co-ordinates and while creating the block you have chosen the basepoint of the block. While inserting the block the the crosshair will be at the point where the blocks basepoint is chosen:cara_con_una_leve_sonrisa:
Click on the "pick points" while creating the block and choose the basepoint as shown in the screenshot.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
Kent1Cooper
@vinodkl wrote:
.... Click on the "pick points" while creating the block and choose the basepoint .....
Exactly.  In the "old days" before the Block command used a dialog box, you had to go through the step of picking an insertion base point in the process of defining a Block.  But for many years now, under the dialog box, 0,0 is always the default insertion base point, though it seldom has any real relationship to the drawn parts of the Block.  It's too easy to not notice, and not give it a base point that has some relationship, so it's common to end up with a meaningless base point.  I wish it would somehow not let you proceed  without specifying a meaningful  one, but I don't know how that could be done with a dialog-box interface.  Maybe it would be a little less meaningless if the default base point would always be something like the current center of the screen, instead of 0,0.
After it has happened a few times, you will start to remember that every time you define a Block, you need to specify a base point that makes sense for it.
Kent Cooper, AIA
0 Me gusta
rafael_simatic
Community Visitor
Community Visitor
I have the same problem. Thanks @Kent1Cooper
0 Me gusta
Valentin-WSP
@rafael_simatic ,
Try setting UCS and PLAN to World.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
