When I run scripts in ACAD, unknown commands error
davidzFY14
Message 1 of 10
davidzFY14
Hello. as the image showed, in AutoCAD Magyar (Hungarian), script does not work well.
How to run it correctly?
Replies (9)
Message 2 of 10
tramber
Well, it is obviously a problem that language with no accent don't have !
just put FOLIA instead of FÔLIA or any accent.
You know ?
In French, if i write the word "line" in my language, "LIGNE", it is ok if i write "Lïgné", for exmple. It is ok in the command palette wich must be kind of interpretor.
But if i write with accents in the script then i got :
lïgné Commande inconnue "LA¯GNA©"
Conclusion : remove accents in the script
Message 3 of 10
davidzFY14
Hi friend, thanks for your reply.
I just try to modify it and remove the accents in the script, then run the script, but it shows FOLIA is unknown commands.
So script won't be run correctly if it have  commands with accents in it?
Message 4 of 10
davidzFY14
Message 5 of 10
tramber
You must remove the "-" too 😁😉
Did i forget to tell U ? 😎
[Edit] FOLIA is a command; -FOLIA is a command with no dialog box so you can train and improve your script
But with script, "-" is not required and not understood[edit]
Scripts have some laws. But you got them now
Message 6 of 10
davidzFY14
yes, I tried but it still didn't work.
the script runs well in English version.
Just want to use this script to set the drawing size, so it doesn't work for Language Hungarian
Message 7 of 10
tramber
I am sorry and a bit surprised.
Don't know if it helped.
Don't know why FOLIA (that i don't know) doesn't work...
Message 8 of 10
JTBWorld
Add underscore _ before the English command names and command arguments and it will work for other languages too. Example _-LAYER
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 9 of 10
cadffm
I disagree 100%, why are you writing that?
Any (not)working sample for us?
@davidzFY14
Check your setting here
Sebastian
Message 10 of 10
tramber
Well,
You are right... i don't know why i had that in mind...
I wrote so many of them, a time ago !
Maybe an habit to remove them, i don't know.
I didn't check and thought about -PAN, and i told myself that maybe I was saying something stupid.
Pleased to an answer in this thread, i thought too fast that it could be a reason.
Anyway, i am experienced with accents, we got some in French, and could verify what i said on that.
Sorry for what i said on : -
