Dear All,
I am facing a issue when When explod block all dimensions dissassociate from original location, Kindly help me int his to resovel this problem.
Please refer attached screenshot
Solved by paullimapa. Go to Solution.
Cannot tell by looking at your screen shot.
Are you saying before the explode all those red lines were not there?
Perhaps you can share that drawing with the block for everyone here to try?
@vinod.sharmaMCCV8 schrieb:
Red lines are after explod,
just a shortlook via Autocad web, without explainations:
You can't change it. There are problem in object data, you can'tfix.
Re-create after explode or inside your Block.
Sebastian
