When coping and pasting, text, element and xrefs are automatically mirroring and rotating. Why?
Message 1 of 11
When coping and pasting from one document to another, text, elements and xref are automatically mirroring and rotating.
My mirrortext in set to 0.
Can anyone help?
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Rotated aka different UCS settings between the two DWG files most likely.
Message 3 of 11
Is there something else I can do? The ucs settings didn't fix the issue. I have add this xref into other sheets and I am not having this issue.
Message 4 of 11
pendean
Community Legend
Community Legend
Can you post both the source DWG file and the destination DWG file (with the pasted text as shown in your screenshot) here for us to look into?
Message 5 of 11
Message 6 of 11
Patchy
Both DWG files, snap shots don't help.
Message 7 of 11
Do you want me to upload the actual dwg files?
Message 8 of 11
pendean
Community Legend
Community Legend
Yes, actual DWG files.
Message 9 of 11
See attached.
Message 10 of 11
pendean
Community Legend
Community Legend
You have to come to the website, tap the REPLY button, to post/share files.
Message 11 of 11
shonemml
In my case when this happened to me the PURGE command solved the problem and it appeared probably because you have the same element block, with the same name in the drawing you are copying to and before paste and PURGE you mast delete old name block or rename new block.
