What's wrong with line command
When I draw lines in new drawings everything works normally.
but in the file that I have attached the line command is working wired, when I draw line and watch in 3d SWisometric looks like presspull command is working simultaneously, I can't draw a normal line. This is same with circle, polyline and more. Not sure what to do.
I have attached the file please open and draw something and reply if the problem is with you also.
imadHabash
you need to change your THICKNESS value = 0 . also you can from Properties dialog change this value for existing line elements . select all those lines then type Ctrl+1 and change Thickness value to Zero . 🙂
Command: THICKNESS
Enter new value for THICKNESS <0'-9 7/64">: 0
Imad Habash
imadHabash
click on below image to see how it's solved .
Imad Habash
@imadHabash
Thank you so much for the solution.
