What program should I use
I am trying to convince my boss to invest in this product.  We are a crane company and would primarily use this product to create 3D lift plans.  What product should I use?
For 3D designs, I would recommend Autodesk Inventor Professional.
I might disagree JC depending on how detailed the lift plan is. I'm a little familiar with lift plans and, if I'm not mistaken, it's a matter of determining max/min swing radius based on surrounding obstructions. It seems that a whole lot of detail wouldn't be necessary. AutoCAD will fit the bill. However, if you need a lot of detail, I would agree that Inventor may be the way to go. Also, just as an FYI. We do 3d scanning which allows for detailed sight survey in a matter of hours. This could be very helpful for lift plans. However, it can be a considerable investment in software, hardware, and training. You also have the option of farming the scanning out to a subcontractor on an as needed basis. Just my humble opinion.
cadwomen
mh
not 100% positv, but if it this what i thougt
http://www.3dliftplan.com/Info/InfoHome.aspx
take a look there
cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Autocad
Cranimax
LiftPlanner
- I do Automation on Crane Lifting Plans & SPT/SPMT Trailer Arrangement...
,please check AutoCad Drawing Automation sample from link
https://youtu.be/bFj73_oKCZU
simoncourtney
Observer
Observer
that is a seriously clever crane block. im impressed with that👍
