What is wrong with these Polylines?
abbas.baghernezhad
Message 1 of 27
abbas.baghernezhad
These polylines come out of Pronest Software. I can't use trim on them. As you can see there is a symbol shown like it is not allowed to trim! If I make the polyline attribiute closed as "NO", the error goes away. I can't figure out why this happens and how to make the polyline cured! If I set closed as "Yes", the error comes back! the same happens for exploding and joining. It is very interesting to know what is wrong with these PLs!
Replies (26)
Message 21 of 27
cadffm
Hi @abbas.baghernezhad
Now I feel a bit stupid, but it can happen (only those who say nothing don't say the wrong thing) 🙄.
Thanks for the second example which brought me back on track.
I think the problem comes from the arc segments,
these are extremely minimally deviating from 90° and the
The assumption is that it leads to rounding errors in the program / a math problem.
If I correct the Arc data, Trim behaves as expected again,
or at least better than before, lol.
Ask:
Can you please explain to us how the polygon was created?
Which command, which inputs, please give us step-by-step instructions to follow.
What is particularly interesting here is the specification of the rounding,
i.e. how the arches were created.
I took one of you bot plines from the second 'sample.dxf'
please test it on your side.
Sebastian
Message 22 of 27
cadffm
or were the polygons created somewhere else and you moved/copied/scaled them?
I'm looking forward to your instructions.
Sebastian
Message 23 of 27
abbas.baghernezhad
No, Unfortunately that doesn't work.
Message 24 of 27
abbas.baghernezhad
Thank You for your attention to the subject.
Pronest is a nesting software. We import the parts (polylines) as DXFs or DWGs and export nests. As a matter of fact I think you are right, parts comes out of Pronest with a slight difference in size and shape which is negligable in production process. for example a dimension of 100mm comes out as 99.9998 ot something like that. Or we never get our circles as circles! they are always exported as a polyline with 2 arcs. (a 90 and a 270 degrees arcs) We don't know what happens inside Pronest but the polylines are closed which means... they are not acutually 100% closed.
It is intersting!!!
Is there something we can do about it?
Message 25 of 27
cadffm
Are my edited plines working?
Do you have 90° ONLY, or also other arc segments
Sebastian
Message 26 of 27
TheCADnoob
This is an interesting one...
The only way i can duplicate any similar behavior with items i create is by creating a spline... its like a polyline is behaving like a spline in regards to trim.
You can use boundary to create a new polyline.
CADnoob
Message 27 of 27
abbas.baghernezhad
Well Said! boundary works!
