What is the name of my custom toolbar?
No aplicable
I am currently using AutoCad 2014 sp1, in classic mode with custom toolbars. It was quite a task creating the tool bars
when I upgraded to 2014. We have signed up to upgrade to 2016.
Will the upgrade recognize my current classic setup and keep it, or will I need to start over again?
0 Me gusta
Responder
Soluciones aceptadas (1)
312 Vistas
3 Respuestas
Respuestas (3)
beyoungjr
AutoCAD classic is gone in 2016:(
Toolbars can still be imported from an old CUI so your work custom toolbars need to be in a saved CUI from 2014 to use on a clean 2016. Clean would be the best way to go but 2014 and 2016 can exist on the same PC if necessary.
Blaine Young
Senior Engineering Technician, US Army
0 Me gusta
No aplicable
Thank you. Just to clarify. If I install a clean and separate version of 2016, I can continue to use my current 2014 until I am satisfied that the CUI transfer is working correctly in 2016. Victor E.Kollasch Project Manager Balmer Architectural Group, Inc. 2425 E. Camelback Rd., Suite 775 Phoenix, Az. 85016 ph: 602-954-6718 fx: 602-468-9680 vkollasch@bag-inc.com
0 Me gusta
rkmcswain
Solución aceptada
vkollasch wrote:
Thank you. Just to clarify. If I install a clean and separate version of 2016, I can continue to use my current 2014 .....
Yes, they will run concurrently from a technical standpoint.
From a licensing standpoint, consult your EULA and the T&C of your subscription agreement (if any).
As far as the toolbars. I would suggest creating a new empty "vkollasch.cuix" file and keep this in a folder like "C:\CADSTUFF".
Put your toolbars, ribbon, pull-down, whenever, in this CUIX file.
Then simply load this menu as a partial menu in 2014, 2016, 2017, etc, etc...
No migration, no headaches, done. It will help you today and tomorrrow.
0 Me gusta
