what is the difference between LA (LAYER) AND -LA (-LAYER).
ncv.smg
ncv.smg
hello,
Please Help me...
0 Me gusta
Responder
822 Vistas
6 Respuestas
Respuestas (6)
cadffm
The main difference is that -Layer works without gui dialog window and palette, it is to use via commandline and macro script and (send)command as well.
PS: For usual people found some difference between the dialog version and the commandline version and THEN they ask WHY? (Answer: Because they are different commands and Adesk did it so).
Sebastian
No aplicable
AS above, the -la command is great when using scripts for functions, there are also some additional features not available on the la palette.
I prefer the -la function rather than the pallet as it also allows me to view the stuff Autocad finds which is hidden to the palette user.
I specifically us the -la command to purge out eh Registry files, great for reducing errors and file size.
0 Me gusta
dmfrazier
I think your first question has been answered, but (maybe) not the second one:
"how to create an option (- layer)..??"
The options listed in the image are the built-in options for that AutoCAD command. To run one of the command options, enter the highlighted letter or click it with your pointer.
Users cannot create/add options to a built-in AutoCAD command.
Kent1Cooper
@ncv.smg wrote:
.... how to create an option (- layer)..?? ....
So Message 4 made me wonder -- what exactly do you mean by that?  What kind of option would you want that isn't already there, i.e. what might you want to do involving Layers that isn't covered among the existing options?  If by chance by (- layer) you mean an option to make a certain Layer the current  one to draw on, that's what the Set option does, or if you want to create  another Layer, the New and Make options do that, but it's just a guess that you might mean one of those.
Kent Cooper, AIA
0 Me gusta
cwr-pae
One thing I didn't see the others mention: If you have a layer filter active and click the new layer button in the layer manager gui, you get a message the layer doesn't match the filter and have to change the filter to name the layer and adjust it. With -la;n;<type name>;; (; = the enter key) you create a layer at the keyboard and avoid the layer filter issue. You can also set color, linetype, etc, though I usually prefer to move the layer manager for that.
0 Me gusta
Alfred.NESWADBA
>> match the filter
To avoid this: my layer-filters have "Layer*" included, so if AutoCAD adds a layer "Layer1" or "Layer2" ... it will ist hte new layer in every of my layer-filters.
Just my 2c, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
