Hi, there.
I think this is a simple question.
I'm always curious what is difference between "AutoCAD Application" and "DWG Launcher"
Please reply me !
Thank you 🙂
Solved by Alfred.NESWADBA. Go to Solution.
"AutoCAD application" is just a pointer to the file "ACAD.EXE" of a specific AutoCAD version.
If you have more than one release of AutoCAD installed or you have more than one vertical product installed (like Map 3D, Civil 3D, AutoCAD Architecture, ...) then:
Assigning "AutoCAD Application (e.g. 2019)" to be used as default application for a double-click of a DWG-file then always this 2019 acad.exe will be opened when you double-click a dwg-file.
When you have assigned "AutoCAD DWG Launcher" as the default handler for DWG-files then a double click of the DWG-file will open that AutoCAD release (and vertical product) you had previously used or which is currently open.
HTH, - alfred -
If you have more than one product on your system, they both are listed as 'AutoCAD Application' on the 'Open with' list with no indication which is which! Eg I have AutoCAD and Civil3D on my machine but the 'Open with' list has the same icon for both so no way to distinguish them beyond a guess. Do you know how to tell the difference?
Edit: I'm using Windows 10, other operating systems might be different
"Open With" lets you only select the file, not any parameter and so you can't use this method to decide if plain AutoCAD or Civil 3D should be started.
To assign parameters you might create a BAT-file, there you can place the full start parameters for your acad.exe (so you also can apply the parameter "/product C3D") ... but that is definitely not a recommended method!
Easiest is always:
- alfred -
That is how I normally work - with a few hiccups when I have both programs open at the same time and a drawing opens in the 'wrong' one because I forget to do 'open..' from inside the program. I was just wondering if there was a way to tell the difference.
In general I try to avoid that, I had my issues with saved back profiles after closing the application then.
When I would have 2 times AutoCAD open I never use a double click to open a dwg-file, I use drag & drop (dwg-file to the command-line area) to decide in which task I want the drawing file opened.
- alfred -
Didn't realise you could drag & drop - I just use the 'open' command but drag & drop might speed me up. Thanks!
Drag'n'drop to STARTtab or Commandline -> open file
Drag'n'drop to editor by left mouse -> insert file
Drag'n'drop to editor by right mouse -> insert file, open file, xref file, create hyperlink to this file
Drag'n'drop to toolpalette -> create an 'insert'(file) tool
and... more.
>"when I have both programs open at the same time"
Nothing to do with if or how many files are open in whatever how many instance and versions.
>"and a drawing opens in the 'wrong' one because I forget to do 'open"
AcLauncher will try to start a file "with the last used version" !
LastUsed = the last version who was closed (you will find an registry key, if you are searching for)
