What happened to my Blocks Palette...It's Gone.
Dewaine_Fisher
Dewaine_Fisher
I had my blocks palette docked to the side of my screen and accidently closed it. Now I can't get it back. I thought the insert command would bring it back up, but all it does is say "*Insert a block from the Blocks palette". I've checked tool palettes, tool bars, my CUI, Options, and can't find the palette anywhere. How do I get it back?
nrz13
Try entering BLOCKSPALETTE at the command line.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Dewaine_Fisher
I've tried both the BLOCKSPALETTE and BLOCKSPALETTECLOSE commands and neither do anything.
nrz13
If you go to OPTIONS > Profiles tab, and select a default profile (or any other profile, really), does the palette show up (when you enter BLOCKSPALETTE at the command line if it's not already showing)?
pendean
Community Legend
Community Legend
Then read this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Palettes-will-not-...
Dewaine_Fisher
This worked. I wish I knew what I did to lose it to begin with, but I'm back up and working. Thank you so much.
