what does text override H1x mean
yairMSKTU
yairMSKTU
in the text override, what does \H1x;\W0.75;<> mean ?
are there any othe edit prefix for text override ?
thanks
0 Me gusta
Responder
294 Vistas
2 Respuestas
Respuestas (2)
Kent1Cooper
The H is for the text Height, followed by a multiplier and an x [times], so 1x has no effect [try a different number].  The W is for the Width factor.  The <> stands in for the measured value, so replace that if you want it to say something different [dangerous], or remove it if you don't want a measurement to be part of the text.
Edit the text of a Dimension, playing with all the possibilities in the ribbon editor [font, color, italics, underlining, etc.], and you'll see the coding format for all those options.
Kent Cooper, AIA
cadffm
you used the wording "text override", so I am not sure, but it sounds you are talking dimensions?
The Dimtext is a MTEXT objects, so can also test near to all the internal formats with MText
and there options in MTexteditor ribbon or toolbar.
The main format controle code: [F1] Link for you
Sebastian
0 Me gusta
