What are some tips to reduce Autocad graphics strain on my computer.
xnguyenFKXUE
Message 1 of 11
xnguyenFKXUE
I picked up a drawing from my predecessor and it does not render well when I zoom in (see picture). I've resorted to just copying the details one at a time to a fresh drawing with my models xref. It was rendering well up until about the 6th detail I pasted there. When I'm done modifying the details I just paste it back into the drawing. Now I need work on it as a whole but I can't do it if my drawing becomes likes the picture. I don't have hardware acceleration on, I've purged multiples times and audited., and the file is only 760 kb big. What are some ways that I can section off pieces of my drawing to make AutoCAD focus on those objects.
Replies (10)
Message 2 of 11
Patchy
Solution: To turn off the preview of annotative objects: On the AutoCAD command line, enter SELECTIONANNODISPLAY. When prompted to enter a new value, enter 0.
Message 3 of 11
xnguyenFKXUE
That did not help much, even when I isolated the detail.
Message 4 of 11
Patchy
Looks like there are more than one viewport.
Message 5 of 11
pendean
Community Legend
Community Legend
Se your annotative scale to 1:1 then REGENALL.
If you still see that mess, share that DWG file here, your workflow is likely the issue, none of it has anything to do with "...graphics strain on my computer...".
TIA
Message 6 of 11
xnguyenFKXUE
It is at a 1:1 scale and I've tried REGENALL. The thing is everything renders just fine when I copy and paste them to a new drawing. But that doesn't work if I copy all of it to a new drawing. It probably something with the workflow but I'm trying to just trying to get a quick fix for this drawing rather than redrawing everything.
Message 7 of 11
pendean
Community Legend
Community Legend
Share your problem DWG file here please.
Message 8 of 11
xnguyenFKXUE
Here's my drawing. Ignore the missing fields and I've detached my models. The issue is still there anyways. Thank you for the assistance.
Message 9 of 11
xnguyenFKXUE
Here's a quick screen record of my issue.  (fyi Window+G is screen record for anyone that didn't know)
Message 10 of 11
pendean
Community Legend
Community Legend
Your Map3D/Civil3D content plus Shademode not set to 2D seems to be the contributing issue to the display problem in the file as you describe it. See attached, I recreated your layout and remove the other as well.
Is your AutoCAD session offering up this suggestion by chance (or did you opt to "stop showing it")? Better suggestions as also offered there
Message 11 of 11
Patchy
Try and see if this helps any.
