weld.lsp Will Not WORK ???
No aplicable
I have loaded the Welds LISP (with SBL and DCL) Chris Crain's automated weld symbol.
I moved the three files to where I keep all of my LSP commands and renamed them WELD.LSP, WELD.DCL & WELD.SLB.
Then on the cammand line in ACAD i entered APPLOAD and loaded the LSP,
Everytime I try to use the command "WELD" I get an Error stating: File Not Found WELD.DCL
Can ANYONE Help
0 Me gusta
Responder
Soluciones aceptadas (1)
1.501 Vistas
6 Respuestas
Respuestas (6)
Patchy
It was posted as zip file and what is the reason you have to rename them?
No aplicable
The file names in the lisp code are called WELD.LSP, WELD.DCL & WELD.SLB. If I donot change the names I get the same errors. I have found the same code from multiple users and I get the same results.
0 Me gusta
Patchy
Solución aceptada
Try put all of them in SUPPORT Folder
Type in:
(findfile "support")
that is where you put all 3 of them.
Exit autocad and restart.
Jonathan3891
You need a support pointed to the location of the Weld.DCL
Jonathan Norton
Blog | Linkedin
0 Me gusta
No aplicable
May I know where I can get this weld lisp from?
0 Me gusta
ВeekeeCZ
On cadalyst...
http://cadtips.cadalyst.com/standard-blocks/automated-weld-symbols
0 Me gusta
