Hi , i need help fix the Select Grip Points. see picture for better understanding . thanks
Solved by john.vellek. Go to Solution.
Hi @fsalman,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
This might be a symptom of Hardware Acceleration in your GRAPHICSCONFIG. Try toggling it to see if that fixes the problem.
Is this happening in all your files?
Can you tell me your OS and your graphics card make and model? I am wondering if a different driver might improve this.
Hi @fsalman,
Did you try my suggestions to correct the issue? If this is only happening on two files, can you share them with me? Please try running AUDIT and then checking the location of your geometry relative to 0,0. If it is too far away it might cause such an error.
HI @fsalman,
Did you have an luck in getting the grip locations corrected? Please let me know the status of your issue.
