Weird frame around workspace !?
OGOUN
Message 1 of 27
OGOUN
Hi there !
In the latest 2025 version I do have an annoying white frame around the workspace...do you have the same and do you know if it can be removed ?
Thanks a lot !
GR
EG
Replies (26)
Message 2 of 27
pendean
Community Legend
Community Legend
Nothing like that in our office
Do you need to turn off GFXDX12 by chance?
Have you run this tool to tone down your ACAD2025 settings yet?
Message 3 of 27
OGOUN
Hey thanks for your answer...!
I didn't tried any tricks with DirectX and that's what I have here in ACAD2025:
Message 4 of 27
pendean
Community Legend
Community Legend
Yeah, my pop-up looked like that too but I had graphics issues (different from yours for sure) until I turned off GFXDX12 here. it's worth trying, just remember you have to restart 2025 for it to take effect (same if you turn it back on).
Message 5 of 27
OGOUN
Well...I turned it off with the key GFXD12 set to "0" and restarted and I still have this anoying frame !   : )
Message 6 of 27
Patchy
Attach your .dwg and see why.
Message 7 of 27
OGOUN
Here it is!
Message 8 of 27
Patchy
One is the viewport and the other is the border on top , nothing unusual that I can see.
Message 9 of 27
pendean
Community Legend
Community Legend
Message 10 of 27
pendean
Community Legend
Community Legend
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 11 of 27
Patchy
What? it's not the same drawing posted with the problem, what do you see there that I don't see?
Did you even open the attached drawing Dean?
Message 12 of 27
pendean
Community Legend
Community Legend
@Patchy wrote:
...Did you even open the attached drawing Dean?
That was the screenshot I shared...
Message 13 of 27
Patchy
Then that's what I see in layout.
Message 14 of 27
pendean
Community Legend
Community Legend
I suspect VPMAX is all the OP needed to do in the MODELSPACE to resolve it, this has come up today in a different post.
Either way, it looks like something else got tagged as the solution by the OP.
Message 15 of 27
Paul_Gander
@OGOUN It looks like your document window may not be maximised  properly. What does toggling the centre button do for you?
Message 16 of 27
OGOUN
Hi again and thanks for all this help.!
@Paul_Gander  Well...no...it's not the problem unfortunately !
@pendeanyeah no solutions for now...
But...now when I open a new drawing I do have this weird frame...but if open a second one, then the frame disappears on that one AND on the first one:
Message 17 of 27
cadffm
Good catch!
Reproduceable on my side. Looks like a kind of bug what appears by STARTMODE 0 ONLY (testers: don't forget the restart after startmode change)
Start a support-case or alert this "problem" by others ways to AutoDESK!
Sebastian
Message 18 of 27
OGOUN
@cadffm  Yeah I have STARTMODE 0 on my ACAD!
I'll report this to Autodesk right now.
Message 19 of 27
OGOUN
Seems tricky to report this to Autodesk...I'll let this like that.
Message 20 of 27
cadffm
You ask "all" users for help, so think about "all" user for a fix! Be so kind.
Report it as "new bug 2025" and add a link to your thread/ or to my post - if you like.
https://www.autodesk.com/support/contact-support
Sie bitten „alle“ Benutzer um Hilfe, denken Sie also an „alle“ Benutzer, um eine Lösung zu finden! Sei so nett.
Sebastian
