Warning: Settings variable "is_objdata" error?
qnologi
Advisor Advisor
qnologi
Working with AutoCAD 2023 with all of it's updates.
Getting this error message when opening a drawing.
Warning: Settings variable 'is_objdata' has a file/path '1' which is not found and will be ignored.
Has anyone seen this? If so, what is it and how do I get rid of it?
Thank you for your time.
qnologi
pendean
Community Legend
Community Legend
So this happens with one single DWG file?
Or all DWG files, even if you start a new file?
And which add-on or add-in or 3rd party program do you use in/with AutoCAD 2023?
qnologi
So far it is only happening with one dwg.
If we start a new drawing, using out template, everything seems fine.
I currently use AutoCAD 2023 (vanilla) T.53.0.0
Together with Carlson Survey 2023
I have attached the dwg in question.
qnologi
pendean
Community Legend
Community Legend
No such error message here, must be something tied to your systems (you seem to be using MAP3D, not the topic of this forum) or Carlson
But in plain AutoCAD - RECOVER command found
And you might need to also run RECOVER command on all the XREFs too:
Items Purged | Purge Status
Blocks.................... | Purged : 120
Registry Applications..... | Purged : 104
Layers.................... | Purged : 377
Line types................ | Purged : 74
Dimensions................ | Purged : 3
Text Styles............... | Purged : 21
Mleader Styles............ | Purged : 21
Here is how to fix one single troublesome file (long list) from Autodesk https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corru...
pendean
Community Legend
Community Legend
Not sure why you still run 2023 with no updates, that's always the first thing you always need to check and fix ASAP (restart your computer afterwards)
qnologi
Thank you for your help. The update fixed it.
qnologi
