如果这不是正确翻译,请原谅 - 我正在使用Google翻译。
如果您的意思是布局标题表(请参见下图),那么您需要在模型空间中绘制它,然后将其作为外部参考附加到布局上。
Pardon if this is not translating properly - I am using Google translate.
If you mean the layout title sheet (see image below), then you need to draw it in Model Space and then attach it as an xref onto your layout.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
