AutoCAD Forum
Vpfreeze symbol in layer manager
7 REPLIES 7
Message 1 of 8
BWYarger
467 Views, 7 Replies
I have upgraded from 2021 to 2024, and have a problem seeing the new vpfreeze symbol in the layer manager, and layer pull-down.  Is there a way to revert to the vpfreeze old symbol in layer manger, or just use the same symbols as regular freeze in the vpfreeze column.
Brad
LT, C3D 2005 - 2024
Windows XP, Vista, 7, 10, 11
Labels (1)
7 REPLIES 7
Message 2 of 8
paullimapa
in reply to: BWYarger
Not unless you want to go back to that version
Paul Li
IT Specialist
@The Office
Message 3 of 8
pendean
@BWYarger wrote:
...have a problem seeing the new vpfreeze symbol in the layer manager, and layer pull-down....
Show us what you see: share a screenshot.
Also share with us a screenshot of your 2024's ABOUT command pop-up as well as a screenshot of your 2024's GRAPHICSCONFIG command pop-up please.
Message 4 of 8
BWYarger
in reply to: pendean
Attached are three AutoCAD Civil 3D screenshots from 2024 and 2018.  I am only allowed three attachments, so I will reply a second time with the graphicsconfig.  The VPFreeze symbol in 2024 is has a much smaller sun/snowflake portion than in 2018.  I just noticed that the other symbols are smaller too.  I moved the VPFreeze column next to the regular freeze column.  The defpoints layers have the viewport frozen symbol while the other have the thawed.
Brad
LT, C3D 2005 - 2024
Message 5 of 8
BWYarger
GraphicsConfig screenshots for 2024 and 2018 attached.
Brad
LT, C3D 2005 - 2024
Message 6 of 8
pendean
Thanks for the screenshots: your white background is much brighter than mine and I see those washed out colors on your screen are very had to see.
About all you can do inside these newer AutoCAD/C3D versions is the following:
EDIT: I don't know if would make much of a difference, but you could try setting GFXDX12 to 0 (that's a zero)  then restart your C3D to see if that is any better (set it back to 1 if not).
Message 7 of 8
BWYarger
Thanks.  I tried both suggestions, and neither worked for me.  I hope Autodesk will go back to the old symbols, but for now I will just have to struggle through it.  It is a shame when they break something that was working fine.
Brad
LT, C3D 2005 - 2024
Message 8 of 8
paullimapa
Perfect opportunity to let Autodesk know
https://www.autodesk.com/company/contact-us/product-feedback
Paul Li
IT Specialist
@The Office
Forma Design Contest
