Visual Style of Hidden Objects
jcronin
Message 1 of 9
jcronin
The situation:
I have a grading plan that is a 3D solid, when I plot the drawing I have created with the grading plan referenced into it I will be plotting using the Legacy Hidden plot style.  i do not want to show the grading plan as it has many edges, but I want anything below (having a lesser Z value) to plot as a hidden line.  I can achieve this with the following system variable settings-but not without having to include the grading plan.  Any suggestions?  Flatten, flatshot, drawing view is not an option.
System variables:
DISPSILH = 1
OBSCUREDLTYPE = 2
Replies (8)
Message 2 of 9
john.vellek
Hi @jcronin,
I think I understand what you are asking but to be certain, can you share a drawing where you have this set up?
I assume that a section plane or live section won't work for what you are trying to display.
John Vellek
Message 3 of 9
jcronin
See attachments-imagine the rectangle as a grading drawing and the cylinder as a conduit/pipe.  Negative on the other two options either.  They will only be plan drawings also, i did include a ortho view in the example just for clarification but were only  talking about the left most viewport set to legacy hidden plot style.  I cant use the exact files that I am working with for copyright issues but the idea here is exactly the same.  Thanks John.
Message 4 of 9
john.vellek
Hi @jcronin,
Just a quick thought before I dive into this, would changing the grading solid to color 255,25,255 work?
John Vellek
Message 5 of 9
jcronin
Negative, plotting using monochrome.ctb.  (screenshot from plot preview)
Message 6 of 9
john.vellek
Hi @jcronin,
I set the color to 25,255,255 and then set the visual style to Wireframe in the left hand view.
Here are my plot settings:
John Vellek
Message 7 of 9
jcronin
I believe that your able to do that because the "plot with plot styles" box is unchecked, mine must be checked. I could not recreate what you did.
Message 8 of 9
john.vellek
Hi @jcronin,
Try my version of your file.  I have applied a pagesetup with the plot settings (with the Plot Style selected).  I have attached the resulting PDF output also for your review.
John Vellek
Message 9 of 9
jcronin
I see what you did now, it worked. It worked on my drawing as well! Brilliance and thanks a million!  The whole time I'm thinking system variable somewhere or unloading a reference.
