Viewports control points missing
GD.ON
GD.ON
My veiwports controls are missing. VPCONTROL is set on 1, but cannot drag the corner as there's no point there...Any suggestions please?
GD.ON
Hi, seems like all edge controls are missing - including MTEXT or geometry...🙄
K_Kubat
grips are turned off
switch them on via grips = 2
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-97AD30F3-A1A3-4027-91B7-49008841A447
or Use Options, Selction, Show grips
GD.ON
Thanks. I have reset ACAD settings to default to fix the issue, but this solution would probably solve the issue. Thank you!
