viewport unlock/lock option not shown in shortcut window
petergil
petergil
I used to be able to right click on a viewport and an option to lock or unlock was there. The option is no longer in the shortcut window. How do I turn it on??
Responder
Soluciones aceptadas (1)
3.045 Vistas
14 Respuestas
Respuestas (14)
Kent1Cooper
First left-click-select the Viewport on its boundary, then right-click.
Kent Cooper, AIA
0 Me gusta
Patchy
If the viewport is on locked layer, then it can't.
0 Me gusta
petergil
The viewport is not locked.
If I left click the viewport then right click a shortcut box comes up but no option to lock, unlock, off, etc. I used to be able to but since upgrading to 2021 this started happening. Am I missing something in "options" say under shortcut menu??
0 Me gusta
petergil
0 Me gusta
Patchy
Oops, I gave you a wrong answer.
Ask the Civil3d group and see if it happens to them with 2021 version.
0 Me gusta
Kent1Cooper
If that's a change in 2021, you can at least pick Properties... from that pop-up menu -- locking of the Viewport should be a choice in the Misc category [unless that has also changed].
Kent Cooper, AIA
petergil
I think you're right its a civil 3d shortcut menu gliche. Ill post there...
0 Me gusta
GustavoUbriaco
hi there! how about this option in the status bar?
Gustavo Ubriaco Contreras
0 Me gusta
petergil
Yes excellent that works I didnt realize they added a lock/unlock button at the bottom. ty.
The right click shortcut menu shows viewport options in autocad but not in Civil 3d. I dont know why. It must be a Civil 3d issue....
0 Me gusta
RobDraw
Not sure when it was added but it's been in AutoCAD for quite some time.
Rob
0 Me gusta
GustavoUbriaco
excellent! We are here to help us each other!
0 Me gusta
petergil
So it looks like has happened before a glitch in the CUI. See below link to another post....
C3D 2021 - Viewport lock does not appear in the Right Click Menu anymore - Autodesk Community - Civi...
I do not dare change the CUI.
Hopefully Autodesk will read this and fix the error for the next update!
petergil
Solución aceptada
HERE IS THE SOLUTION..in CIVIL 3D forum...thanks to Jeff M
Why not? It takes less than 30 seconds...here's a short screencast of how to do so:
https://autode.sk/37Zmf3c
Draughter83
Fantastic, thank you for the link to the fix.
0 Me gusta
