AutoCAD Forum
Viewport scale toolbar issue
3 REPLIES 3
w64bit
235 Views, 3 Replies
I found a viewport scale toolbar issue which can be replicate like this: - create a viewport - turn on Viewports toolbar - select viewport (the scale should not be a standard/default defined scale 1:1, 1:2 ...) - in Viewports toolbar click once on scale input box > the content will be selected - copy and paste in a text editor - the number of digits for the non standard/default scale is 20 - if the scale digits is less than 20, the rest of the digits will filled with spaces Can anyone confirm this?
3 REPLIES 3
GustavoUbriaco
in reply to: w64bit
hi there could you share an image please?
Gustavo Ubriaco Contreras
neaton
in reply to: w64bit
Yes, I can duplicate it. Are you trying to use the scale someplace like a LISP routine or is this just an anomaly you discovered?
Nancy
w64bit
in reply to: neaton
Screenshot = the selection is made of 4.954 value + 15 spaces.
Can anyone at Autodesk please submit this (I already did on feedback page).
Thank you.
Forma Design Contest
