Viewport Scale - Standard and Custom Scale.
rimutaka
rimutaka
HI,
How to set up view port scale in Standard scale (1: 50; 1 : 100 etc)  instead of Custom Scale (0.0066; 0.001 etc?
Each time I try to set my view port scale in Standard scale, my drawing objects disappear from view port window. This is not happened in Custom Scale.
Thank you
ennujozlagam
@rimutakahello, this what i do go to layout paper space > go inside your viewport > zoom the object you want to scale > in the command prompt type zoom > 1/10xp which is 10 is your viewport scale. thanks
What is your drawing/object unit? meter/centimeter/millimeter?
1. Make sure your drawing units in millimeters (default scale in mm)
2. Enable viewport (double left click - zoom & pan your drawing position)
3. Select the scale you want (choose custome to Add Scale List )
john.vellek
Hi @rimutaka,
I just ran across your post and wanted to see if you still needed assistance in setting up your viewport scales in your drawings. This AKN Article might show you how to set up a ScaleList.
John Vellek
