Anuncios
viewport scale problem
No aplicable
Hi everyone. Does anybody knows why i cant write 20 in the viewport scale control tab? i cant put 15,16,17 etc. but not 20!!! i have to write 20.0!!!
0 Me gusta
Responder
Soluciones aceptadas (1)
824 Vistas
10 Respuestas
Respuestas (10)
imadHabash
would you please show us a screenshot for the viewport scale control tab ? also yo may need to unlock your viewport ( maybe ) .
Imad Habash
0 Me gusta
No aplicable
The VP is unlocked...
0 Me gusta
imadHabash
i see from your attached that you can write 20 !! isn't ? if you start a new CAD drawing did your issue still exist ? if yes would you please share with us your CAD drawing sample as AutoCAD 2013 format type ?
Imad Habash
0 Me gusta
No aplicable
i cant write 20!!!! i can write 20.0(......17, 18, 19, 20.0). this is really weird. its not a big deal but i cant understand why! for years i just wrote 20. from today i have to write 20.0
0 Me gusta
Alfred.NESWADBA
I can write 20, in the toolbar as well as in the property window ... and after <ENTER> all is well, view is updated.
What do you mean by "I can't write 20" ... do the letters not appear in the field or what is the issue?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
If i write 20 i loose my scale!(it zooms out). i must type 20.0 (twenty point zero) to keep the correct scale
0 Me gusta
Alfred.NESWADBA
is that drawing dependent?
Can you please create a video from that behavior (e.g. using >>>Autodesk Screencast<<<) + show a screenshot from command _ABOUT so we can see your version of AutoCAD?
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I found the guilty. look at the diferrence between 20 and 20.0. i dont know how that happened. Now how can i delete it. it wont delete and it doesnt let me edit.
0 Me gusta
Alfred.NESWADBA
good catch!
When you can't delete it then this scale is in use, either by a default setting, or by a viewport or by any annotative objects. If you can't delete it sometimes it's a help to rename it :cara_guiñando_un_ojo:
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Solución aceptada
leave it i found it! double click and change name(close cad and reopen it)!!!! thanks guys!
0 Me gusta
