Hello Community,
Current Setup:
I'm using AutoCAD Electrical 2020, but this issue is not specific to the toolset. In a paper space layout I setup my title block and a viewport to model space, in model space I have a rectangle with the viewport's dimensions, which I use as my border for the schematics. In the title block (layout) I show via field the viewport scale factor, usually 1:1.
My Problem:
When I'm not making wiring schematics but a panel layout I need to extend beyond the viewport borders and thus change the scale factor in the viewport to show all, I want this to happen automatically without changes to my layout. The changed scale factor should be reflected in the title block, also only standard scale factors should be used.
My attempted solution:
I scale the rectangle in model space (which represents my viewport borders) as needed (only in standard scale steps) to enclose my complete model. I set the viewport on paper space layout on scale "Scale to Fit".
The issue:
The viewport "Scale to Fit" takes a little more space than the model, resulting in non-standard scales.
Example:
I make in model space a rectangle with 2"x2" dimensions (and anything inside), in paper space layout I make a viewport with 2"x2" dimensions and select "Scale to Fit" - theoretically the resulting "custom" scale factor should be 1:1, but because the viewport also catches a little bit space around the rectangle I get something weird "1:0.xxx-xxxxxxxx" or so. According to my idea I could increase the model rectangle to 20"x20" to fit more details inside and the viewport changes scale to 1:10, but because of above behavior it will show 1:9.5468745631
Any idea's?
Best regards,
Lukas
