Anuncios
Viewport Lineweight - for steel carpentry
s231154
s231154
From the print of a layout I get too much thick lines (visible in the pdf).
I searched all over the web but I can't stand how to plot properly the thickness of any line that is inside a viewport.
I think there should be a way in assigning it without associate color with thickness (CTB).
I use color to emphasize different objects which all should be plotted with same thickness and color (black for all).
Here I attach my dwg
Let me know
Thanks to all who care!!
da182efc-6053-427e-ba87-c984a3c61ad3,640,620
0 Me gusta
Responder
706 Vistas
6 Respuestas
Respuestas (6)
pendean
Community Legend
Community Legend
Uncheck this box
Or change your objects/layers LWEIGHT settings.
s231154
Thank you
I tried unchecking the plot object lineweight - unsuccessfully.
I tried changing the VPlineweight from inside the viewport - unsuccessfully...
I run out of ideas
0 Me gusta
pendean
Community Legend
Community Legend
Did you get a chance to see the PDF I attached: is that a fix or not what you needed?
Show us your PDF with the problem.
0 Me gusta
s231154
Your pdf is same as mine, lines that come from the viewport are bigger then others (I need thin line, just it is absurde I can't control viewport line size, should I redraw all lines just to make the sketch clear?)
0 Me gusta
natasha.l
Hello @s231154
Are you trying to create different lightweights for plotting? Have you created a custom CTB file?
Please take a look at this video to create a custom CTB file.
  • Make sure you have associated your colors in the CTB file properly so that the thickness will appear when you plot. Ex. Color 1 (Red) set to 0.200mm.
  • Then make sure the proper color is assigned to the corresponding layer in Layer Properties, so Color 1 needs to be assigned to the layer you wish.
  • Make sure that all Layer Properties are set properly to plot as well.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
0 Me gusta
s231154
Thank you Natasha,
Even if I hope in a solution not involving CTB, I tried with CTB but pdf print isn't as expected, still there are bigger lines if inside the viewport.
Thank you all
Best Regards
0 Me gusta
